Project->Configuration Options->Memory Settings
tam si nieco zapis a v programe by sa malo dat na to odvolavat. Osobne som to nikdy nepotreboval.
Ak to ale naozaj chces rychlo, preco nepouzit pole v RAM? Pred spustenim nacitas tabulku z Flash do RAM, bude jedno kde je umiestnena a potom uz iba vyberas hodnoty z pola.
co sa rychlosti tyka, nasledovny zdrojak
volatile static uint8_t pole_gen[256], vystup, podmienka_behu = TRUE;
uint8_t aktual_index = 0, *p_pole = NULL, *p_pole_pom;
while (podmienka_behu) {
vystup = pole_gen[aktual_index];
aktual_index++;
aktual_index = 0;
p_pole_pom = (uint8_t *)pole_gen;
if (aktual_index == 0) p_pole = p_pole_pom;
vystup = *p_pole;
p_pole++;
aktual_index++;
return;
mi prekladac prelozil
98: while (podmienka_behu) {
+0000056C: C008 RJMP PC+0x0009 Relative jump
99: if (aktual_index == 0) p_pole = p_pole_pom;
+0000056D: 2388 TST R24 Test for Zero or Minus
+0000056E: F411 BRNE PC+0x03 Branch if not equal
+0000056F: E5E1 LDI R30,0x51 Load immediate
+00000570: E0F5 LDI R31,0x05 Load immediate
100: vystup = *p_pole;
+00000571: 9191 LD R25,Z+ Load indirect and postincrement
+00000572: 93900550 STS 0x0550,R25 Store direct to data space
102: aktual_index++;
+00000574: 5F8F SUBI R24,0xFF Subtract immediate
+00000575: 91900102 LDS R25,0x0102 Load direct from data space
+00000577: 2399 TST R25 Test for Zero or Minus
+00000578: F7A1 BRNE PC-0x0B Branch if not equal
108: }
a jeden cyklus trva 0.65us
zaREMovany kod trva 0.71us
no a da sa to aj takto brutalne ak ide o rychlost a nie o velkost pamate:
jeden krok trva 0.16us
107: while (podmienka_behu) {
+00000569: C050 RJMP PC+0x0051 Relative jump
108: vystup = *(p_pole + 0);
+0000056A: 91800551 LDS R24,0x0551 Load direct from data space
+0000056C: 93800550 STS 0x0550,R24 Store direct to data space
109: vystup = *(p_pole + 1);
+0000056E: 91800552 LDS R24,0x0552 Load direct from data space
+00000570: 93800550 STS 0x0550,R24 Store direct to data space
110: vystup = *(p_pole + 2);
+00000572: 91800553 LDS R24,0x0553 Load direct from data space
+00000574: 93800550 STS 0x0550,R24 Store direct to data space
111: vystup = *(p_pole + 3);
+00000576: 91800554 LDS R24,0x0554 Load direct from data space
+00000578: 93800550 STS 0x0550,R24 Store direct to data space
112: vystup = *(p_pole + 4);
+0000057A: 91800555 LDS R24,0x0555 Load direct from data space
+0000057C: 93800550 STS 0x0550,R24 Store direct to data space
113: vystup = *(p_pole + 5);
+0000057E: 91800556 LDS R24,0x0556 Load direct from data space
+00000580: 93800550 STS 0x0550,R24 Store direct to data space
114: vystup = *(p_pole + 6);
+00000582: 91800557 LDS R24,0x0557 Load direct from data space
+00000584: 93800550 STS 0x0550,R24 Store direct to data space
115: vystup = *(p_pole + 7);
+00000586: 91800558 LDS R24,0x0558 Load direct from data space
+00000588: 93800550 STS 0x0550,R24 Store direct to data space
116: vystup = *(p_pole + 8);
+0000058A: 91800559 LDS R24,0x0559 Load direct from data space
+0000058C: 93800550 STS 0x0550,R24 Store direct to data space
117: vystup = *(p_pole + 9);
+0000058E: 9180055A LDS R24,0x055A Load direct from data space
+00000590: 93800550 STS 0x0550,R24 Store direct to data space
118: vystup = *(p_pole + 10);
+00000592: 9180055B LDS R24,0x055B Load direct from data space
+00000594: 93800550 STS 0x0550,R24 Store direct to data space
119: vystup = *(p_pole + 11);
+00000596: 9180055C LDS R24,0x055C Load direct from data space
+00000598: 93800550 STS 0x0550,R24 Store direct to data space
120: vystup = *(p_pole + 12);
+0000059A: 9180055D LDS R24,0x055D Load direct from data space
+0000059C: 93800550 STS 0x0550,R24 Store direct to data space
121: vystup = *(p_pole + 13);
+0000059E: 9180055E LDS R24,0x055E Load direct from data space
+000005A0: 93800550 STS 0x0550,R24 Store direct to data space
122: vystup = *(p_pole + 14);
+000005A2: 9180055F LDS R24,0x055F Load direct from data space
+000005A4: 93800550 STS 0x0550,R24 Store direct to data space
123: vystup = *(p_pole + 15);
+000005A6: 91800560 LDS R24,0x0560 Load direct from data space
+000005A8: 93800000 STS 0x0000,R24 Store direct to data space
124: vystup = *(p_pole + 16);
+000005AA: 91800561 LDS R24,0x0561 Load direct from data space
+000005AC: 93800550 STS 0x0550,R24 Store direct to data space
125: vystup = *(p_pole + 17);
+000005AE: 91800562 LDS R24,0x0562 Load direct from data space
+000005B0: 93800550 STS 0x0550,R24 Store direct to data space
126: vystup = *(p_pole + 18);
+000005B2: 91800563 LDS R24,0x0563 Load direct from data space
+000005B4: 93800550 STS 0x0550,R24 Store direct to data space
127: vystup = *(p_pole + 19);
+000005B6: 91800564 LDS R24,0x0564 Load direct from data space
+000005B8: 93800550 STS 0x0550,R24 Store direct to data space
+000005BA: 91800102 LDS R24,0x0102 Load direct from data space
+000005BC: 2388 TST R24 Test for Zero or Minus
+000005BD: F009 BREQ PC+0x02 Branch if equal
+000005BE: CFAB RJMP PC-0x0054 Relative jump
130: }
alebo ak je pocet prvkov do 64
jeden krok trva tak isto 0.16us
volatile static uint8_t pole_gen[256], pole_gen2[256], vystup, podmienka_behu = TRUE;
register uint8_t aktual_index = 0, *p_pole = NULL, *p_pole_pom;
if (nejaka_podmienka) p_pole = (uint8_t *)pole_gen;
else p_pole = (uint8_t *) pole_gen2;
sa prelozi ako
105: if (vystup) p_pole = (uint8_t *)pole_gen;
+00000569: 91800550 LDS R24,0x0550 Load direct from data space
+0000056B: 2388 TST R24 Test for Zero or Minus
+0000056C: F019 BREQ PC+0x04 Branch if equal
+0000056D: E5E1 LDI R30,0x51 Load immediate
+0000056E: E0F6 LDI R31,0x06 Load immediate
+0000056F: C03F RJMP PC+0x0040 Relative jump
106: else p_pole = (uint8_t *) pole_gen2;
+00000570: E5E1 LDI R30,0x51 Load immediate
+00000571: E0F5 LDI R31,0x05 Load immediate
+00000572: C03C RJMP PC+0x003D Relative jump
+00000573: 8180 LDD R24,Z+0 Load indirect with displacement
+00000576: 8181 LDD R24,Z+1 Load indirect with displacement
+00000577: 93800550 STS 0x0550,R24 Store direct to data space
+00000579: 8182 LDD R24,Z+2 Load indirect with displacement
+0000057A: 93800550 STS 0x0550,R24 Store direct to data space
+0000057C: 8183 LDD R24,Z+3 Load indirect with displacement
+0000057D: 93800550 STS 0x0550,R24 Store direct to data space
+0000057F: 8184 LDD R24,Z+4 Load indirect with displacement
+00000582: 8185 LDD R24,Z+5 Load indirect with displacement
+00000583: 93800550 STS 0x0550,R24 Store direct to data space
+00000585: 8186 LDD R24,Z+6 Load indirect with displacement
+00000586: 93800550 STS 0x0550,R24 Store direct to data space
+00000588: 8187 LDD R24,Z+7 Load indirect with displacement
+00000589: 93800550 STS 0x0550,R24 Store direct to data space
+0000058B: 8580 LDD R24,Z+8 Load indirect with displacement
+0000058E: 8581 LDD R24,Z+9 Load indirect with displacement
+0000058F: 93800550 STS 0x0550,R24 Store direct to data space
+00000591: 8582 LDD R24,Z+10 Load indirect with displacement
+00000592: 93800550 STS 0x0550,R24 Store direct to data space
+00000594: 8583 LDD R24,Z+11 Load indirect with displacement
+00000595: 93800550 STS 0x0550,R24 Store direct to data space
+00000597: 8584 LDD R24,Z+12 Load indirect with displacement
+0000059A: 8585 LDD R24,Z+13 Load indirect with displacement
+0000059B: 93800550 STS 0x0550,R24 Store direct to data space
+0000059D: 8586 LDD R24,Z+14 Load indirect with displacement
+0000059E: 93800550 STS 0x0550,R24 Store direct to data space
+000005A0: 8587 LDD R24,Z+15 Load indirect with displacement
+000005A1: 93800550 STS 0x0550,R24 Store direct to data space
+000005A3: 8980 LDD R24,Z+16 Load indirect with displacement
+000005A6: 8981 LDD R24,Z+17 Load indirect with displacement
+000005A7: 93800550 STS 0x0550,R24 Store direct to data space
+000005A9: 8982 LDD R24,Z+18 Load indirect with displacement
+000005AA: 93800550 STS 0x0550,R24 Store direct to data space
+000005AC: 8983 LDD R24,Z+19 Load indirect with displacement
+000005AD: 93800550 STS 0x0550,R24 Store direct to data space
+000005AF: 91800102 LDS R24,0x0102 Load direct from data space
+000005B1: 2388 TST R24 Test for Zero or Minus
+000005B2: F009 BREQ PC+0x02 Branch if equal
+000005B3: CFBF RJMP PC-0x0040 Relative jump
130: }
A toto mi prekladac prelozil s nastaveni -O3 zza cas 0.38us na jednu vzorku, je pravda ze uz treba mat napasovany index pola na adresu nula co v predchadzajucich pripadoch nebolo treba
aktual_index = 0;
vystup = *p_pole + aktual_index;
aktual_index++;
93: while (podmienka_behu) {
+0000064E: 91800102 LDS R24,0x0102 Load direct from data space
+00000650: 2388 TST R24 Test for Zero or Minus
+00000651: F049 BREQ PC+0x0A Branch if equal
94: vystup = *p_pole + aktual_index;
+00000652: 91800000 LDS R24,0x0000 Load direct from data space
+00000654: 93800550 STS 0x0550,R24 Store direct to data space
+00000656: 91900102 LDS R25,0x0102 Load direct from data space
+00000658: 5F8F SUBI R24,0xFF Subtract immediate
+00000659: 2399 TST R25 Test for Zero or Minus
+0000065A: F7C9 BRNE PC-0x06 Branch if not equal
trosku som a rozvlacne rozpisal, ale snad ma tato pozdna hodina ospravedlni
Si si isty, ze ten asm je az taky zasadny prinos aby si ho do C-cka vobec montoval?
Xtal 18.432MHz
