Dobry den.
Mam mensi problem s rozchozenim komunikace LCD s timto PICem. Kod vypada nasledovne:
#include <p24hxxxx.h>
#define FCY 10000000UL
void lcd_line1(void); //function prototypes
void lcd_line2(void);
void lcd_cmd(unsigned char);
void lcd_char(char);
void e_togg(void);
void lcd_init(void);
void lcd_string();
void delay(void);
void del_5ms(void);
//void lcd_busy(void);
char sentence[16] = "Tome, lets go!";
char *senpoint = sentence;
#define E LATAbits.LATA1
#define RS LATAbits.LATA0
int main(void)
AD1PCFGL = 0xffff; //all digital
TRISA = 0; //PORTs all outputs
TRISB = 0;
E = 0; //set E low
lcd_init();
delay();
lcd_string(); //send string to LCD
for(;;){} //spin forever
return 0;
void lcd_string(void)
while(*senpoint != '\0')
lcd_char(*senpoint);
senpoint++;
lcd_cmd(0x80);
lcd_cmd(0xc0);
void lcd_cmd(unsigned char letter)
LATB = letter; //put char in PORTB
del_5ms();//lcd_busy();
PORTB = PORTB << 5; //shift over to output high 4 bits on RB9,10,11,12
RS = 0; //RS low
e_togg(); //latch the data
PORTB = PORTB << 4; //shift over to output low 4 bits
RS = 0; //RS low
e_togg(); //latch it
void lcd_char(char letter)
RS = 1; //RS high
RS = 1; //RS high
void lcd_init(void)
LATB = 0x0600; //send 3
e_togg();
delay();//lcd_busy();
LATB = 0x0600;
e_togg();
LATB = 0x0600;
e_togg();
LATB = 0x0400; //send 2 - set 4-bit mode
e_togg();
lcd_cmd(0x28); //set 4-bit mode and 2 lines
lcd_cmd(0x10); //cursor move & shift left
lcd_cmd(0x06); //entry mode = increment
lcd_cmd(0x0d); //display on - cursor blink on
lcd_cmd(0x01); //clear display
void e_togg(void)
E=1;
del_5ms();
E=0;
void delay(void)
int var1,var2;
for(var1=0;var1!=10;var1++)
for(var2=0;var2!=10000;var2++);
void del_5ms(void)
int var1,var2;
for(var2=0;var2!=2000;var2++);
PIC je rizen primarnim oscilatorem (krystal 10 Mhz). Propojeni mezi LCD a PIC:
D4 - RB9
D5 - RB10
D6 - RB11
D7 - RB12
RS - RA0
E - RA1
Nasledujici otazka, nevite v cem je prosim vas problem?
Popravde jsem zkousel i jednodussi programek jenom na otestovani vystupu z PICka.
TRISB = 0; // all PORTB pins output
AD1PCFGL = 0xffff; // all PORTB pins digital
LATB = 0xaa;
Na zadnem pinu na PORTB jsem nenameril napeti log 1.
Dekuji predem za jakkoukoli odpoved.
