Takhle to vypadá v originále:
[code]#define ONE_WIRE_PIN PIN_D2
void onewire_reset() {
output_low(ONE_WIRE_PIN); // pull the bus low for reset
delay_us(500);
output_float(ONE_WIRE_PIN); // float the bus high
delay_us(500); // wait-out remaining initialisation window
void onewire_write(int8 data) {
int8 count;
for(count = 0; count < 8; ++count) {
delay_us(2); // pull 1-wire low to initiate write time-slot.
output_bit(ONE_WIRE_PIN, shift_right(&data, 1, 0)); // set output bit on 1-wire
delay_us(60); // wait until end of write slot.
output_float(ONE_WIRE_PIN); // set 1-wire high again,
delay_us(2); // for more than 1us minimum.
int onewire_read() {
int count, data;
delay_us(2); // pull 1-wire low to initiate read time-slot.
output_float(ONE_WIRE_PIN); // now let 1-wire float high,
delay_us(8); // let device state stabilise,
shift_right(&data, 1, input(ONE_WIRE_PIN)); // and load result.
delay_us(120); // wait until end of read slot.
return data;
float ds1820_read() {
int8 busy=0, temp1, temp2;
signed int16 temp3;
float result;
//ds1820_configure(0x00, 0x00, 0x00); //9 bit resolution
onewire_reset();
onewire_write(0xCC); //Skip ROM, address all devices
onewire_write(0x44); //Start temperature conversion
while(busy == 0) //Wait while busy (bus is low)
busy = onewire_read();
onewire_reset();
onewire_write(0xBE); //Read scratchpad
temp1 = onewire_read();
temp2 = onewire_read();
temp3 = make16(temp2, temp1);
//result = (float) temp3 / 2.0; //Calculation for DS18S20 with 0.5 deg C resolution
result = (float) temp3 / 16.0; //Calculation for DS18B20
delay_ms(200);
return(result);
void main(){
value = ds1820_read();
}[/code]
No a podle mě potřebuju:
[code]void onewire_reset(int ONE_WIRE_PIN) {
delay_us(500);
void onewire_write(int8 data, int ONE_WIRE_PIN) {
int8 count;
int onewire_read(int ONE_WIRE_PIN) {
int count, data;
return data;
float ds1820_read(int ONE_WIRE_PIN) {
signed int16 temp3;
float result;
onewire_reset(ONE_WIRE_PIN);
onewire_write(0xCC,ONE_WIRE_PIN); //Skip ROM, address all devices
onewire_write(0x44,ONE_WIRE_PIN); //Start temperature conversion
busy = onewire_read(ONE_WIRE_PIN);
onewire_write(0xBE,ONE_WIRE_PIN); //Read scratchpad
temp1 = onewire_read(ONE_WIRE_PIN);
temp2 = onewire_read(ONE_WIRE_PIN);
delay_ms(200);
return(result);
void main(){
int ONE_WIRE_PIN;
ONE_WIRE_PIN = 66; // vyčteno z include pro 16f74
value = ds1820_read(ONE_WIRE_PIN);
}[/code]
Což nefunguje vůbec. Pochopil jsem to dobře?
