Nazdar.
Bol bi tu niekto ochotný upraviť tento program? Jedna sa o časovač len potrebujem aby to po skončení pípalo.
Môže sa použit niektorí z portov PC1 až PC7. Inak program funguje.
S písaním programu nemam skúsenosti tak prosím vás. Dakujem
[code]#include <avr/io.h>
#include <avr/interrupt.h>
#include <util/delay.h>
#include “lcd.h”
//Connection of Load
#define LOAD_DDR DDRC
#define LOAD_PORT PORTC
#define LOAD_POS PC0
#define LOAD_PO1 PC1
//Global variable for the clock system
volatile unsigned int clock_millisecond=0;
volatile char clock_second=0;
volatile char clock_minute=0;
volatile char clock_hour=0;
void tim0_start(void);
void Wait(uint8_t n)
uint8_t i,temp;
temp=n*28;
for(i=0;i<temp;i++)
_delay_loop_2(0);
void LoadOn()
LOAD_PORT|=(1<<LOAD_POS);
void LoadOff()
LOAD_PORT&=(~(1<<LOAD_POS));
void LoadOn1()
LOAD_PORT|=(1<<PC1);
void LoadOff1()
LOAD_PORT&=(~(1<<PC1));
main()
while(1)
LOAD_DDR|=(1<<LOAD_POS);
LOAD_DDR|=(1<<LOAD_PO1);
DDRC |= (1<<PC3);
LoadOff();
//Enable Pullups on Keypad
PORTB|=((1<<PB5)|(1<<PB4)|(1<<PB0));
int8_t hr,min,sec; //Target Time
hr=min=sec=0;
//Initialize the LCD Subsystem
InitLCD(0);
//Clear the display
LCDClear();
//Set up the timer1 as described in the
//tutorial
TCCR1B=(1<<WGM12)|(1<<CS11)|(1<<CS10);
OCR1A=250;
//Enable the Output Compare A interrupt
TIMSK|=(1<<OCIE1A);
//Enable interrupts globally
sei();
LCDClear();
LCDWriteString(" Welcome ");
LCDWriteStringXY(0,1," Relay Timer ");
Wait(1);
LCDClear();
LCDWriteString("Set Time - 00:00");
LCDWriteStringXY(0,1," Start ^");
uint8_t selection=1;
uint8_t old_pinb=PINB;
while(1)
while((PINB & 0b00110001) == (old_pinb & 0b00110001));
//Input received
if(!(PINB & (1<<PINB5)) && (old_pinb & (1<<PB5)))
//Selection key Pressed
selection++;
if(selection==3)
selection =0;
if(!(PINB & (1<<PINB4)) && (old_pinb & (1<<PB4)))
//Up Key Pressed
if(selection == 1)
//Min is selected so increment it
min++;
if(min == 60)
min =0;
if(selection == 2)
//Sec is selected so increment it
sec++;
if(sec == 60)
sec =0;
if(selection == 0)
//Start Selected
break;
if(!(PINB & (1<<PINB0)) && (old_pinb & (1<<PB0)))
//Down Key Pressed
if(selection == 1)
//Min is selected so decrement it
min--;
if(min == -1)
min =59;
if(selection == 2)
//Sec is selected so decrement it
sec--;
if(sec == -1)
sec =59;
if(selection == 0)
//Start Selected
break;
old_pinb=PINB;
//Update Display
LCDClear();
LCDWriteStringXY(0,1," Start ");
//min
LCDWriteIntXY(11,0,min,2);
//sec
LCDWriteIntXY(14,0,sec,2);
if(selection == 0)
LCDWriteStringXY(0,1,">");
if(selection == 1)
LCDWriteStringXY(11,1,"^");
if(selection == 2)
LCDWriteStringXY(14,1,"^");
_delay_loop_2(0);
_delay_loop_2(0);
_delay_loop_2(0);
_delay_loop_2(0);
_delay_loop_2(0);
_delay_loop_2(0);
_delay_loop_2(0);
_delay_loop_2(0);
//Start the Load
LoadOn();
LoadOff1();
//Now start the timer
clock_hour = hr;
clock_minute = min;
clock_second = sec;
LCDClear();
LCDWriteString(" Power Off In ");
while(1)
LCDWriteIntXY(7,1,clock_minute,2);
LCDWriteString(":");
LCDWriteIntXY(10,1,clock_second,2);
if((clock_hour == 0) && (clock_minute == 0) && (clock_second == 0))
//Time Out
LoadOff();
LoadOn1();
LCDClear();
LCDWriteString("Load Turned Off");
Wait(2);
LoadOff1();
while(1)
LCDWriteStringXY(0,1,"*Press Any Key*");
Wait(1);
LCDWriteStringXY(0,1," ");
Wait(1);
if((~PINB) & 0b00110001)
break;
break;
_delay_loop_2(0);
_delay_loop_2(0);
_delay_loop_2(0);
_delay_loop_2(0);
//Continue again
//The output compate interrupt handler
//We set up the timer in such a way that
//this ISR is called exactly at 1ms interval
ISR(TIMER1_COMPA_vect)
clock_millisecond++;
if(clock_millisecond==1000)
clock_second–;
if(clock_second==-1)
clock_minute–;
clock_second=59;
if(clock_minute==-1)
clock_hour--;
clock_minute=59;
[/code]
administrator: přejmenováno z "Uprava programu."
