Zdravím, prosím o radu s tímto programem pro dveřní zámek. Při psaní hesla ukazuje hvězdy, potřebuji aby ukazoval to co píšu čísla. Zkoušel jsem ho přepisovat podle různých rad ale bezúspěšně.
Děkuji za každou radu.
'* Digital 8 digit Code Lock (Compatible with AMC8) *
'* Compiler: BASCOM-AVR 2.0.4.0 *
'* Creation Date: 07.April.2011 *
'* Last - Change: 13.April.2011 *
'* Author: Behnam Zakizadeh *
'* License: freeware *
'* © www.avr64.com *
'* Ver: 2.0 *
$regfile = "m8def.dat"
$crystal = 1000000
$framesize = 128
$hwstack = 128
$swstack = 128
'$projecttime = 12
'LCD
Config Lcdpin = Pin , Db4 = Portc.2 , Db5 = Portc.3 , Db6 = Portc.4 , Db7 = _
Portc.5 , E = Portc.1 , Rs = Portc.0
Config Lcd = 16 * 2
Deflcdchar [0] , 8 , 4 , 2 , 4 , 8 , 4 , 2 , 1 ' replace [x] with number (0-7)
'Keypad
Config Kbd = Portd
'Sub's
Declare Sub Init()
Declare Sub Main()
Declare Sub Error()
Declare Sub Ok()
'Function
Declare Function Getpass() As String
Declare Function Star(byval Passwd As String) As String
'Backlight
Config Pinb.2 = Output
Backlight Alias Portb.2
'Relay
Config Pinb.7 = Output
Relay Alias Portb.7
'Main Prog Start Here:
Call Init()
Do
Call Main()
Loop
End
'_______________________________________________________________________________
'Keypad Decode Data Table
Keypad:
Data "1" , "2" , "3" , "Esc"
Data "4" , "5" , "6" , "F2"
Data "7" , "8" , "9" , "F3"
Data "*" , "0" , "#" , "Enter" , "no"
Sub Init()
Cls : Cursor Off Noblink
Set Backlight
Lcd "Digital CodeLock"
Lowerline
Lcd " www.avr64.com"
Wait 1
End Sub
Sub Main()
Lcd "Enter Password:"
Lowerline
Cursor Blink
If Getpass() = "12345678" Then
Call Ok()
Else
Call Error()
End If
End Sub
Sub Ok()
Local _key As Byte
Local _num As String * 5
Cls : Cursor Noblink
Lcd "Door is open!"
Lowerline
Lcd " Esc=Exit"
Set Relay
'for a home open door system remove above line and remark below lines:
' set relay
' waitms 800
' reset relay
Do
_key = Getkbd()
_num = Lookupstr(_key , Keypad)
Loop Until _num = "Esc"
Reset Relay
End Sub
Sub Error()
Lcd "Error!"
Wait 1
End Sub
Local _result As String * 8
Local _count As Byte
Local _length As Byte
_result = ""
_length = Len(passwd)
For _count = 1 To _length
_result = _result + "0"
Next Count
Star = _result
End Function
Local _key As Byte
Local _password As String * 8
_password = ""
Do
_key = Getkbd()
If _num = "0" Or _num = "1" Or _num = "2" Or _num = "3" Or _num = "4" Or _
_num = "5" Or _num = "6" Or _num = "7" Or _num = "8" Or _num = "9" Then
If Len(_password) < 8 Then
_password = _password + _num
Lowerline
Lcd Star(_password)
Do
Loop Until Getkbd() = 16
End If
If Len(_password) = 8 Then Cursor Noblink
End If
If _num = "Esc" Then
_password = ""
Lowerline
Lcd Spc(16)
Lowerline
Cursor Blink
Do
End If
Loop Until _num = "Enter"
Getpass = _password
End Function
'End Of File
administrator: přejmenováno z "Atmega8 - code lock - bascom"
