nejde ethernet
morpheus
PříspěvekZaslal: 04 listopad 2015, 19:56    Předmět: nejde ethernet Citovat
ahoj
pokouším se zprovoznit ethernet s ENC28J60 kod programu je tento
kód:
#include <SPI.h>
#include <UIPEthernet.h>
byte mac[] = {  0xDD, 0xAD, 0xBE, 0xEF, 0xFE, 0xEE };
IPAddress ip(192,168,30,19);
EthernetServer server(80);
void setup()
   Serial.begin(9600);
   Serial.println("Ethernet Begin");
    Ethernet.begin(mac, ip);
   Serial.println("server");
   server.begin();
   Serial.print("server is at ");
   Serial.println(Ethernet.localIP());
void loop()
 /* add main program code here */
   // Is there any client requests?
   // listen for incoming clients
   EthernetClient client = server.available();
   if (client) {
      Serial.println("new client");
      // an http request ends with a blank line
      boolean currentLineIsBlank = true;
      while (client.connected()) {
         if (client.available()) {
            char c = client.read();
            Serial.write(c);
            // if you've gotten to the end of the line (received a newline
            // character) and the line is blank, the http request has ended,
            // so you can send a reply
            if (c == '\n' && currentLineIsBlank) {
               // send a standard http response header
               client.println("HTTP/1.1 200 OK");
               client.println("Content-Type: text/html");
               client.println("Connnection: close");
               client.println();
               client.println("<!DOCTYPE HTML>");
               client.println("<html>");
               // add a meta refresh tag, so the browser pulls again every 5 seconds:
               client.println("<meta http-equiv=\"refresh\" content=\"5\">");
               // output the value of each analog input pin
               for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
                  int sensorReading = analogRead(analogChannel);
                  client.print("analog input ");
                  client.print(analogChannel);
                  client.print(" is ");
                  client.print(sensorReading);
                  client.println("<br />");
               client.println("</html>");
               break;
            if (c == '\n') {
               // you're starting a new line
            else if (c != '\r') {
               // you've gotten a character on the current line
               currentLineIsBlank = false;
      // give the web browser time to receive the data
      delay(1);
      // close the connection:
      client.stop();
      Serial.println("client disonnected");
ale bohužel nejde se v prohližeči připojit.
Serial ukazuje Ethernet Begin
server
server is at 192.168.30.19
tak nevím co může byt kde špatně díky za odpovědi.
