Dobry den, chci se poradit s AD prevodem na vyvojovem kitu discovery STM32F0, pouzivam vyvojove prostredi CoIDE.
V mem kodu AD prevod nefunguje, ale kdyz zakomentuju inicializaci SPI, tak najednou funguje. Nevim v cem je problem, kdyz kod debuguju, tak se zasekne na radku:
while(!ADC_GetFlagStatus(ADC1, ADC_FLAG_EOC));//Processing the conversion
Budu vdecny za kazdou radu.
[code]
#include <stdio.h>
#include <stdlib.h>
#include <math.h>
#include <string.h>
#include <stm32f0xx.h>
#include <stm32f0xx_gpio.h>
#include <stm32f0xx_rcc.h>
#include <stm32f0xx_usart.h>
#include <stm32f0xx_spi.h>
#include <stm32f0xx_adc.h>
#include <stm32f0xx_misc.h>
#include <stm32f0xx_conf.h>
#define LED_GREEN GPIO_Pin_9
#define LED_BLUE GPIO_Pin_8
#define USER_BUTTON GPIO_Pin_0
//DDS RESET
#define DDS_MSTR_RST GPIO_Pin_4 //PA4
//DDS IO UPDATE
#define DDS_IO_UPD GPIO_Pin_6 //PA6
//DDS SCLK
#define DDS_SCLK GPIO_Pin_5 //PA5
#define DDS_SDIO_0 GPIO_Pin_7 //PA7
//SDIO_3
#define DDS_SDIO_3 GPIO_Pin_0 //PC0
//RANGE_1 R = 5k
#define RANGE_1 GPIO_Pin_13 //PB13
//RANGE_2 R = 50R
#define RANGE_2 GPIO_Pin_14 //PB14
//RANGE_3 R = 500R
#define RANGE_3 GPIO_Pin_15 //PB15
//CHANNEL SWITCH
#define CH_SWITCH GPIO_Pin_6 //PC6
//UART RX PA3
//UART TX PA2
void delay_ad9958(int a)
volatile int i,j;
for (i=0 ; i < a ; i++)
j++;
return;
void io_update(void)
GPIO_ResetBits(GPIOA,DDS_IO_UPD);
delay_ad9958(200000);
GPIO_SetBits(GPIOA,DDS_IO_UPD);
return;
void AD9958_Set_Ch0_Phase(unsigned int phase)// in deg
unsigned int PTW = 0;
float temp;
unsigned char CPOW0_1, CPOW0_0;
temp = phase*45.5111;
PTW = (unsigned int)temp;
CPOW0_1 = (PTW & 0x3f00) >> 8;
CPOW0_0 = (PTW & 0x00ff);
GPIO_ResetBits(GPIOC, DDS_SDIO_3);
SPI_SendData8(SPI1,0x00); //CSR registr
delay_ad9958(20000);
SPI_SendData8(SPI1,0x70);
GPIO_SetBits(GPIOC, DDS_SDIO_3);
SPI_SendData8(SPI1,0x05);
SPI_SendData8(SPI1,CPOW0_1);
SPI_SendData8(SPI1,CPOW0_0);
SPI_SendData8(SPI1,0xF0);
io_update();
void AD9958_Set_Freq(unsigned int freq)// frequency in Hz
unsigned long FTW = 0;
float temp;
unsigned char CFTW0_3, CFTW0_2, CFTW0_1, CFTW0_0;
temp = freq*8.589934592;
FTW = (unsigned long)temp;
CFTW0_3 = (FTW & 0xff000000) >> 24;
CFTW0_2 = (FTW & 0x00ff0000) >> 16;
CFTW0_1 = (FTW & 0x0000ff00) >> 8;
CFTW0_0 = (FTW & 0x000000ff);
SPI_SendData8(SPI1,0x04); //CFTWo registr
SPI_SendData8(SPI1,CFTW0_3);
SPI_SendData8(SPI1,CFTW0_2);
SPI_SendData8(SPI1,CFTW0_1);
SPI_SendData8(SPI1,CFTW0_0);
io_update();
void USART_Send_String(USART_TypeDef* USARTx,volatile char *str)
while(*str)
while(USART_GetFlagStatus(USARTx,USART_FLAG_TXE) == RESET);
USART_SendData(USARTx,*str);
str++;
float AD_conversion(char channel)
unsigned int pom;
float pom2;
if (channel == 0)
ADC_ChannelConfig(ADC1, ADC_Channel_8, ADC_SampleTime_239_5Cycles); //8~PB0;9~PB1
else
ADC_ChannelConfig(ADC1, ADC_Channel_9, ADC_SampleTime_239_5Cycles);
ADC_StartOfConversion(ADC1);
pom = ADC_GetConversionValue(ADC1);
pom2 = (float) pom;
pom2 = pom2*(3.0/4096);
return(pom2);
/========== global_variables ==========/
char rec_buffer[10];
unsigned int RxCnt;
unsigned int MyNumber;
unsigned int MyNumberValid;
double R; //rezistor in bridge
int main(void)
float value;
char print_value[50];
int i = 0;
GPIO_InitTypeDef GPIO;
USART_InitTypeDef USART;
SPI_InitTypeDef SPI;
ADC_InitTypeDef ADC_InitStructure;
NVIC_InitTypeDef NVIC_InitStructure;
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA,ENABLE);
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOB,ENABLE);
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOC,ENABLE);
RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2,ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1,ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);
GPIO_PinAFConfig(GPIOA, GPIO_PinSource2, GPIO_AF_1);
GPIO_PinAFConfig(GPIOA, GPIO_PinSource3, GPIO_AF_1);
GPIO_PinAFConfig(GPIOA, GPIO_PinSource5, GPIO_AF_0);
GPIO_PinAFConfig(GPIOA, GPIO_PinSource7, GPIO_AF_0);
/==================USART=====================/
GPIO.GPIO_Pin = GPIO_Pin_2 | GPIO_Pin_3;
GPIO.GPIO_Mode = GPIO_Mode_AF;
GPIO.GPIO_OType = GPIO_OType_PP;
GPIO.GPIO_PuPd = GPIO_PuPd_NOPULL;
GPIO.GPIO_Speed = GPIO_Speed_Level_3;
GPIO_Init(GPIOA,&GPIO);
USART.USART_BaudRate = 9600;
USART.USART_WordLength = USART_WordLength_8b;
USART.USART_StopBits = USART_StopBits_1;
USART.USART_Parity = USART_Parity_No;
USART.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
USART.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
USART_Init(USART2, &USART);
USART_Cmd(USART2, ENABLE);
NVIC_InitStructure.NVIC_IRQChannel = USART2_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPriority = 3;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
USART_ITConfig(USART2, USART_IT_RXNE, ENABLE);
/==================SPI=====================/
GPIO.GPIO_Pin = DDS_SCLK | DDS_SDIO_0;
GPIO.GPIO_Pin = DDS_MSTR_RST | DDS_IO_UPD;
GPIO.GPIO_Mode = GPIO_Mode_OUT;
GPIO.GPIO_Speed = GPIO_Speed_Level_1;
GPIO.GPIO_Pin = DDS_SDIO_3;
GPIO_Init(GPIOC,&GPIO);
SPI.SPI_Direction = SPI_Direction_1Line_Tx;
SPI.SPI_Mode = SPI_Mode_Master;
SPI.SPI_DataSize = SPI_DataSize_8b;
SPI.SPI_CPOL = SPI_CPOL_Low;
SPI.SPI_CPHA = SPI_CPHA_1Edge;
SPI.SPI_NSS = SPI_NSS_Soft;
SPI.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_256;
SPI.SPI_FirstBit = SPI_FirstBit_MSB;
SPI_Init(SPI1, &SPI);
SPI_Cmd(SPI1,ENABLE);
/===========DEAFULT_DDS_SETTINGS=============/
GPIO_SetBits(GPIOA, DDS_MSTR_RST);
GPIO_ResetBits(GPIOA, DDS_MSTR_RST);
SPI_SendData8(SPI1,0x00); //CSR registr, channel settings
SPI_SendData8(SPI1,0x01); //FR1 registr, PLL divider
SPI_SendData8(SPI1,0xD0);
SPI_SendData8(SPI1,0x20);
//default frequency 100 kHz
AD9958_Set_Freq(100000);
SPI_SendData8(SPI1,0x06); //amplitude 333 mV
SPI_SendData8(SPI1,0b00010000);
SPI_SendData8(SPI1,0x15);
io_update();
/==================OTHERS=====================/
GPIO.GPIO_Pin = LED_BLUE | LED_GREEN | CH_SWITCH;
GPIO.GPIO_Pin = RANGE_1 | RANGE_2 | RANGE_3;
GPIO_Init(GPIOB,&GPIO);
GPIO.GPIO_Pin = USER_BUTTON;
GPIO.GPIO_Mode = GPIO_Mode_IN;
GPIO_SetBits(GPIOC, LED_BLUE);
GPIO_ResetBits(GPIOC, LED_GREEN);
/==================ADC=====================/
GPIO.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1;
GPIO.GPIO_Mode = GPIO_Mode_AN;
ADC_DeInit(ADC1);
ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;
ADC_InitStructure.ADC_ContinuousConvMode = DISABLE;
ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None;
ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
ADC_InitStructure.ADC_ScanDirection = ADC_ScanDirection_Backward;
ADC_Init(ADC1, &ADC_InitStructure);
ADC_Cmd(ADC1, ENABLE);
while(1)
//if(strcmp(rec_buffer, "m\r")==0)
USART_Send_String(USART2,"voltage: ");
value = AD_conversion(1);
sprintf(print_value,"%f",value); //lf for double
USART_Send_String(USART2, print_value);
USART_Send_String(USART2,"\r\n");
for(i=0;i<11;i++)
rec_buffer* = ‘\0’;
RxCnt = 0;
delay_ad9958(1500000);
void USART2_IRQHandler(void)
char char_buff;
char buff[50];
int i = 0;
if((USART_GetITStatus(USART2, USART_IT_RXNE) != RESET))
char_buff = (unsigned char)(USART_ReceiveData(USART2));
sprintf(buff,"%c",char_buff);
USART_Send_String(USART2,buff);
if(char_buff == 13)
MyNumber = atoi(rec_buffer);
if (MyNumber > 0)
MyNumberValid = 1;
for(i=0;i<11;i++)
rec_buffer* = '\0';
RxCnt = 0;
rec_buffer[RxCnt] = char_buff;
RxCnt++;
[/code]*
