ARM AT9260 + data na SDRAM
steev
Založen: 8.1.2010
PříspěvekZaslal: 20 únor 2014, 10:03    Předmět: ARM AT9260 + data na SDRAM Citovat
Čaute,
vedeli by ste mi prosím poradiť, ako dostať v AT9260 dáta na SDRAM-ku (adresa 0x200000)? Čítal som nejaké matroše okolo nastavenia lds skriptu, ale nejako mi to nefunguje... akonahle zadam adresu -Tdata 0x20000000, tak mi program po kompiláci nefunguje.
moj Makefile:
kód:
ifndef ERASE_FCT
ERASE_FCT=rm -f
endif
ifndef CROSS_COMPILE
CROSS_COMPILE=arm-elf-
endif
TOOLCHAIN=gcc
OUTFILE_SDRAM=at91sam9260_getting_started_sdram
INCL=./include
# Comment the line below for debug mode
#OPTIM=-Os
ifeq ($(TOOLCHAIN), gcc)
AS=$(CROSS_COMPILE)gcc
CC=$(CROSS_COMPILE)gcc
LD=$(CROSS_COMPILE)gcc
NM= $(CROSS_COMPILE)nm
SIZE=$(CROSS_COMPILE)size
OBJCOPY=$(CROSS_COMPILE)objcopy
OBJDUMP=$(CROSS_COMPILE)objdump
CCFLAGS=-g -mcpu=arm9 $(OPTIM) -Wall -I$(INCL)
ASFLAGS=-D__ASSEMBLY__ -g -mcpu=arm9 -c $(OPTIM) -Wall -I$(INCL)
# Linker flags.
#  -Wl,...:     tell GCC to pass this to linker.
#    -Map:      create map file
#    --cref:    add cross reference to map file
#  -lc       :    tells the linker to tie in newlib
#  -lgcc   :    tells the linker to tie in newlib
LDFLAGS+=-nostartfiles -Wl,--cref
LDFLAGS+=-lc -lgcc
LDFLAGS+=-T elf32-littlearm.lds
OBJS=cstartup.o
endif
OBJS+= lowlevel.o \
       main.o
rebuild: clean all
all: sdram
sdram: $(OBJS)
   $(LD) $(LDFLAGS) -Ttext 0x20000000 -Tdata 0x200000 -n -o $(OUTFILE_SDRAM).elf $(OBJS)
   $(OBJCOPY) --strip-debug --strip-unneeded $(OUTFILE_SDRAM).elf -O binary $(OUTFILE_SDRAM).bin
main.o: main.c
   $(CC) -c $(CCFLAGS) main.c -o main.o
lowlevel.o: lowlevel.c
   $(CC) -c $(CCFLAGS) lowlevel.c -o lowlevel.o
emac.o: emac.c
   $(CC) -c $(CCFLAGS) emac.c -o emac.o
cstartup.o:  cstartup.S
   $(AS) $(ASFLAGS) cstartup.S -o cstartup.o
clean:
   $(ERASE_FCT) *.o *.bin *.elf *.map
.lds subor:
kód:
OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm")
OUTPUT_ARCH(arm)
ENTRY(reset_handler)
/*#include "project.h"*/
SECTIONS
   .text : {
      _stext = .;
      *(.text)
      *(.rodata)                 /* read-only data (constants) */
      *(.rodata*)
      . = ALIGN(4);
       _etext = . ;
   /* collect all initialized .data sections that go into FLASH  */
   .data : AT ( ADDR (.text) + SIZEOF (.text) ) {
      _sdata = .;
      *(.vectors)
      *(.data)
      _edata = .;
   /* collect all uninitialized .bss sections that go into FLASH  */
   .bss (NOLOAD) : {
      . = ALIGN(4);
      _sbss = .;
      *(.bss)
      _ebss = .;
      /* koli problemu pri kompilacii */
   /DISCARD/ :
        *(.eh_*)
end = .;
za každú radu vopred vďaka.
mares.vit
Účastník
Účastník
Založen: 19.9.2012
PříspěvekZaslal: 24 březen 2014, 8:05    Předmět: Citovat
V makefilu dáváte sekci kódu do SDRAM a data do SRAM.
