Dobrý den, mám problém ohledně kódu. Když nahraju tento program, tak kurzor začne blikat na 3. políčku na první lajně a nic jineého se nezobrazí. Mám to jako projekt do školy a piny do lcd už jsou dány. že RC0 je RS, RC1 je RW a RC2 je E. A databity jsou RC4-RC7. Porad´te prosím.
- This code will interface to a standard LCD controller
- like the Hitachi HD44780. It uses it in 4 bit mode, with
- the hardware connected as follows (the standard 14 pin
- LCD connector is used):
- PORTD bits 0-3 are connected to the LCD data bits 4-7 (high nibble)
- PORTC bit 0 is connected to the LCD RS input (register select)
- PORTC bit 2 is connected to the LCD EN bit (enable)
- PORTC bit 1 is connected to the LCD RW bit (read or write)
- To use these routines, set up the port I / O (TRISE, TRISD) then
- call Init_lcd (), then other routines as required.
#include <pic.h>
#include <htc.h>
#include <stdio.h>
#define _XTAL_FREQ 20000000
#define EN_TRIG ((LCD_EN = 1),(LCD_EN = 0));
static bit LCD_RS @ ((unsigned)&PORTC8+0); // Register select
static bit LCD_EN @ ((unsigned)&PORTC8+2); // Enable
static bit LCD_RW @ ((unsigned)&PORTC*8+1); // R/W
//Functions
void DelayMs (int x);
void DelayUs (int x);
void Init_lcd (void);
void Write_com_lcd (unsigned char c);
void Write_char_lcd (unsigned char c);
void Write_string_lcd (const char * s);
void Clear_lcd (void);
void Goto_lcd (unsigned char pos);
void main ()
ADCON1 = 0x0e; // Set PORTA as digital port
TRISC=0;
Init_lcd(); // LCD Initialization
Clear_lcd(); // Reset LCD and move to start position
Write_string_lcd(“Micro”);
while(1);
LCD_RW = 0; // write to LCD
LCD_RS = 0; // write control bytes
DelayMs(150); // power on delay
PORTD = 0x3; // attention!
EN_TRIG;
DelayMs(5);
EN_TRIG;
DelayUs(100);
EN_TRIG;
DelayMs(5);
PORTD = 0x2; // set 4 bit mode
EN_TRIG;
DelayUs(40);
Write_com_lcd(0x28); // 4 bit mode, 1/16 duty, 5x8 font
Write_com_lcd(0x08); // display off
Write_com_lcd(0x0F); // display on, blink curson on
Write_com_lcd(0x06); // entry mode
void DelayMs(int x)
int y=(x*1000)/15;
while(–y != 0)
continue;
void DelayUs(int x)
int y = x/15;
while(–y != 0)
continue;
void Write_com_lcd(unsigned char c)// send command to lcd
LCD_RW = 0;
LCD_RS = 0; // write the command
PORTC = (PORTC & 0xF0) | (c >> 4);
EN_TRIG;
PORTC = (PORTC & 0xF0) | (c & 0x0F);
EN_TRIG;
DelayUs(40);
void Write_char_lcd(unsigned char c)
LCD_RW = 0;
LCD_RS = 1; // write characters
EN_TRIG;
EN_TRIG;
DelayUs(40);
void Write_string_lcd(const char * s)
while(*s)
Write_char_lcd(*s++);
void Clear_lcd(void)
LCD_RS = 0;
Write_com_lcd(0x1);
DelayMs(2);
void Goto_lcd(unsigned char pos)
LCD_RS = 0;
Write_com_lcd(0x80+pos);
